Ana içeriğe geç
LG Watch Urbane Motherboard Replacement
Neye ihtiyacın var
  1. LG Watch Urbane Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG Watch Urbane Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Motherboard Replacement: adım 2, 2 resimden 1. LG Watch Urbane Motherboard Replacement: adım 2, 2 resimden 2.
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Motherboard Replacement: adım 3, 3 resimden 1. LG Watch Urbane Motherboard Replacement: adım 3, 3 resimden 2. LG Watch Urbane Motherboard Replacement: adım 3, 3 resimden 3.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Motherboard Replacement: adım 4, 3 resimden 1. LG Watch Urbane Motherboard Replacement: adım 4, 3 resimden 2. LG Watch Urbane Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • And now you have your motherboard
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rey Diaz
699 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Remmell Fall 2015 USF Tampa, Team 1-4, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 1,158
