Ana içeriğe geç
LG X Power Camera Replacement
Neye ihtiyacın var
  1. LG X Power Camera Replacement, LG X Power Disassembly: adım 1, 2 resimden 1. LG X Power Camera Replacement, LG X Power Disassembly: adım 1, 2 resimden 2.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Camera Replacement: adım 2, 2 resimden 1. LG X Power Camera Replacement: adım 2, 2 resimden 2.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Camera Replacement: adım 3, 2 resimden 1. LG X Power Camera Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Camera Replacement, Main Camera: adım 4, 2 resimden 1. LG X Power Camera Replacement, Main Camera: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
Sonuç
Chad Sears
1.149 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Spring 2018 USF Tampa, Team S3-G6, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 614
