Ana içeriğe geç
LG X Power Charging Port Replacement
Neye ihtiyacın var
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: adım 1, 2 resimden 1. LG X Power Charging Port Replacement, LG X Power Disassembly: adım 1, 2 resimden 2.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: adım 2, 2 resimden 1. LG X Power Charging Port Replacement: adım 2, 2 resimden 2.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: adım 3, 2 resimden 1. LG X Power Charging Port Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: adım 4, 3 resimden 1. LG X Power Charging Port Replacement, Charging Port: adım 4, 3 resimden 2. LG X Power Charging Port Replacement, Charging Port: adım 4, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: adım 5, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: adım 6, 1 resimden 1.
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: adım 7, 1 resimden 1.
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Chad Sears
1.149 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Spring 2018 USF Tampa, Team S3-G6, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G6
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 5,915
