Giriş
This guide will show you how to replace the charging port on a LG X Power smartphone.
Neye ihtiyacın var
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
5 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Where can i get the charging port part? There are so many different usb female ports.
