Ana içeriğe geç
LG X Style Screen Replacement
Neye ihtiyacın var
    1. LG X Style Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Power down the device and make sure that it is turned off.
      • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
      • Gently twist tool clockwise until the back case pops open [this will create a small gap].
      • Slide the tool along the gap around the entire device.
      FixBot'a Sor
      Yorum Ekle
    2. LG X Style Screen Replacement: adım 2, 2 resimden 1. LG X Style Screen Replacement: adım 2, 2 resimden 2.
      • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG X Style Screen Replacement, Screen: adım 3, 2 resimden 1. LG X Style Screen Replacement, Screen: adım 3, 2 resimden 2.
      • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. LG X Style Screen Replacement: adım 4, 3 resimden 1. LG X Style Screen Replacement: adım 4, 3 resimden 2. LG X Style Screen Replacement: adım 4, 3 resimden 3.
      • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
      • Slide prying tool around entire device beginning toward the top.
      • Lift off and remove the screen from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 1,864
