Ana içeriğe geç
LG Xenon Speaker Replacement
Neye ihtiyacın var
  1. LG Xenon Speaker Replacement, Back Case: adım 1, 1 resimden 1.
    • Turn the phone so the back side is face up.
    FixBot'a Sor
    Yorum Ekle
  2. LG Xenon Speaker Replacement: adım 2, 2 resimden 1. LG Xenon Speaker Replacement: adım 2, 2 resimden 2.
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
    FixBot'a Sor
    Yorum Ekle
  3. LG Xenon Speaker Replacement, Battery: adım 3, 2 resimden 1. LG Xenon Speaker Replacement, Battery: adım 3, 2 resimden 2.
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
    FixBot'a Sor
    Yorum Ekle
  4. LG Xenon Speaker Replacement, Motherboard: adım 4, 2 resimden 1. LG Xenon Speaker Replacement, Motherboard: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Xenon Speaker Replacement: adım 5, 1 resimden 1.
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
    FixBot'a Sor
    Yorum Ekle
  6. LG Xenon Speaker Replacement: adım 6, 2 resimden 1. LG Xenon Speaker Replacement: adım 6, 2 resimden 2.
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. LG Xenon Speaker Replacement: adım 7, 2 resimden 1. LG Xenon Speaker Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. LG Xenon Speaker Replacement: adım 8, 2 resimden 1. LG Xenon Speaker Replacement: adım 8, 2 resimden 2.
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
    FixBot'a Sor
    Yorum Ekle
  9. LG Xenon Speaker Replacement: adım 9, 2 resimden 1. LG Xenon Speaker Replacement: adım 9, 2 resimden 2.
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. LG Xenon Speaker Replacement: adım 10, 2 resimden 1. LG Xenon Speaker Replacement: adım 10, 2 resimden 2.
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
  11. LG Xenon Speaker Replacement, Keyboard: adım 11, 1 resimden 1.
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
    FixBot'a Sor
    Yorum Ekle
  12. LG Xenon Speaker Replacement, LCD: adım 12, 1 resimden 1.
    • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
    FixBot'a Sor
    Yorum Ekle
  13. LG Xenon Speaker Replacement: adım 13, 1 resimden 1.
    • Remove slider piece.
    • Pay close attention that you don’t lose the spring.
    • Carefully remove the spring.
    FixBot'a Sor
    Yorum Ekle
  14. LG Xenon Speaker Replacement: adım 14, 2 resimden 1. LG Xenon Speaker Replacement: adım 14, 2 resimden 2.
    • Remove six 2.25mm Phillips #00 screws along the outside of the case.
    FixBot'a Sor
    Yorum Ekle
  15. LG Xenon Speaker Replacement: adım 15, 2 resimden 1. LG Xenon Speaker Replacement: adım 15, 2 resimden 2.
    • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
    FixBot'a Sor
    Yorum Ekle
  16. LG Xenon Speaker Replacement: adım 16, 1 resimden 1.
    • Remove the black electrical tape holding the LCD to the screen.
    FixBot'a Sor
    Yorum Ekle
  17. LG Xenon Speaker Replacement: adım 17, 1 resimden 1.
    • Un-clasp the small tab in the top right corner.
    FixBot'a Sor
    Yorum Ekle
  18. LG Xenon Speaker Replacement: adım 18, 3 resimden 1. LG Xenon Speaker Replacement: adım 18, 3 resimden 2. LG Xenon Speaker Replacement: adım 18, 3 resimden 3.
    • Unhook the LCD from tabs on the bottom using the plastic opening tool.
    • Remove the LCD. Be careful, the LCD screen is fragile.
    FixBot'a Sor
    Yorum Ekle
  19. LG Xenon Speaker Replacement, Speaker: adım 19, 2 resimden 1. LG Xenon Speaker Replacement, Speaker: adım 19, 2 resimden 2.
    • The speaker is attached to the top of the LCD.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Micaela Saqui
78 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-41, Regan Spring 2012 Cal Poly, Team 9-41, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G41
5 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 1,192
