Giriş
If the audio on the phone isn't working, you may want to try replacing the speaker.
Neye ihtiyacın var
Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
Turn the motherboard over and carefully remove the keypad from the motherboard.
The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
Bir başkası bu kılavuzu tamamladı.
