Ana içeriğe geç
LG env2 vx9100 Back Panel Replacement
Neye ihtiyacın var
  1. LG env2 vx9100 Back Panel Replacement, Battery: adım 1, 3 resimden 1. LG env2 vx9100 Back Panel Replacement, Battery: adım 1, 3 resimden 2. LG env2 vx9100 Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Back Panel Replacement, Back Panel: adım 2, 2 resimden 1. LG env2 vx9100 Back Panel Replacement, Back Panel: adım 2, 2 resimden 2.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Back Panel Replacement: adım 3, 2 resimden 1. LG env2 vx9100 Back Panel Replacement: adım 3, 2 resimden 2.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Back Panel Replacement: adım 4, 2 resimden 1. LG env2 vx9100 Back Panel Replacement: adım 4, 2 resimden 2.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Reed Williston
34 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G55
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 797
