Giriş
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
Parçalar
Hiçbir parçaya gerek yok.
  1. Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone facedown on the table.
    • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Lift the battery out.
  2. Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  5. Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  6. Locate the ribbon attached to the lens of the camera. Place the plastic opening tool in between the logic board and ribbon.
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  7. Place the plastic opening tool in between the lens and the logic board. Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Reed Williston
34 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G55
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 372
