Ana içeriğe geç
Giriş
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's speaker.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the phone upside down so that the bottom of the back is facing you. Turn the phone upside down so that the bottom of the back is facing you.
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off. Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. Gently remove the battery from the device.
    • Gently remove the battery from the device.
  4. Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone. Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics. Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
  5. After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail. Be careful when doing this to avoid breaking the phone plastics, it should release easily. Be careful when doing this to avoid breaking the phone plastics, it should release easily.
    • After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail.
    • Be careful when doing this to avoid breaking the phone plastics, it should release easily.
  6. Lastly remove the speaker using the plastic opening tool. Lastly remove the speaker using the plastic opening tool. Lastly remove the speaker using the plastic opening tool.
    • Lastly remove the speaker using the plastic opening tool.
Sonuç
Nathanael Knight
181 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S3-G1, Harley Spring 2018 IUPUI, Team S3-G1, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 69
