Ana içeriğe geç
LG-P970 touch screen Replacement
Neye ihtiyacın var
  1. LG-P970 touch screen Replacement, touch screen: adım 1, 3 resimden 1. LG-P970 touch screen Replacement, touch screen: adım 1, 3 resimden 2. LG-P970 touch screen Replacement, touch screen: adım 1, 3 resimden 3.
    • remove the back cover
    • remove the battery
    • remove the SIM card
    • remove the µSD card (Memory)
  2. LG-P970 touch screen Replacement: adım 2, 3 resimden 1. LG-P970 touch screen Replacement: adım 2, 3 resimden 2. LG-P970 touch screen Replacement: adım 2, 3 resimden 3.
    • remove 7 screws on the back
    • with a tool start to open the back frame
    • and it's now easy to remove the back frame with hand, carefully
  3. LG-P970 touch screen Replacement: adım 3, 3 resimden 1. LG-P970 touch screen Replacement: adım 3, 3 resimden 2. LG-P970 touch screen Replacement: adım 3, 3 resimden 3.
    • remove buttons
    • locate the back camera
    • with a tool raise up the led.carefully
  4. LG-P970 touch screen Replacement: adım 4, 3 resimden 1. LG-P970 touch screen Replacement: adım 4, 3 resimden 2. LG-P970 touch screen Replacement: adım 4, 3 resimden 3.
    • with a tool disconnect the back camera
    • and remove the camera with your fingers.
  5. LG-P970 touch screen Replacement: adım 5, 2 resimden 1. LG-P970 touch screen Replacement: adım 5, 2 resimden 2.
    • don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
  6. LG-P970 touch screen Replacement: adım 6, 3 resimden 1. LG-P970 touch screen Replacement: adım 6, 3 resimden 2. LG-P970 touch screen Replacement: adım 6, 3 resimden 3.
    • It's time to remove carefully the tactile screen.
    • don't scratch le LCD!!!
  7. LG-P970 touch screen Replacement: adım 7, 3 resimden 1. LG-P970 touch screen Replacement: adım 7, 3 resimden 2. LG-P970 touch screen Replacement: adım 7, 3 resimden 3.
    • the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
    • cut new double sided tape (1-2mm width), put it on the are and peel it.
  8. LG-P970 touch screen Replacement: adım 8, 3 resimden 1. LG-P970 touch screen Replacement: adım 8, 3 resimden 2. LG-P970 touch screen Replacement: adım 8, 3 resimden 3.
    • remove the inside protection on the new touch screen.
    • carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
    • to finish, add all part by reading these instructions in reverse ;-)
    • and try if it work !
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Fox4EGX
545 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Hi. To take the screws out do I need a phillips? Thanks.
schutze61 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 9,750
