Ana içeriğe geç
LaCie Rugged USB-C Circuit Board Replacement
Neye ihtiyacın var
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: adım 1, 3 resimden 1. LaCie Rugged USB-C Circuit Board Replacement, Overview: adım 1, 3 resimden 2. LaCie Rugged USB-C Circuit Board Replacement, Overview: adım 1, 3 resimden 3.
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: adım 2, 2 resimden 1. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: adım 2, 2 resimden 2.
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: adım 3, 2 resimden 1. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: adım 3, 2 resimden 2.
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: adım 4, 2 resimden 1. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: adım 4, 2 resimden 2.
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: adım 5, 2 resimden 1. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: adım 5, 2 resimden 2.
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: adım 6, 1 resimden 1.
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: adım 7, 1 resimden 1.
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: adım 8, 1 resimden 1.
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
9021007
4.599 İtibar
25 adet Kılavuz yazıldı
3 Yorum
Where can i get a new board? thank you
Bar Avraham - Yanıt
Yes, where can we find a new board?
Vassilis Trigkas - Yanıt
Right, where can the part be purchased?????
James Causey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 65
Her zaman: 1,553
