Ana içeriğe geç
LaCie Rugged USB-C Hard Drive Replacement
Neye ihtiyacın var
  1. LaCie Rugged USB-C Hard Drive Replacement, Overview: adım 1, 3 resimden 1. LaCie Rugged USB-C Hard Drive Replacement, Overview: adım 1, 3 resimden 2. LaCie Rugged USB-C Hard Drive Replacement, Overview: adım 1, 3 resimden 3.
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: adım 2, 2 resimden 1. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: adım 2, 2 resimden 2.
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: adım 3, 2 resimden 1. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: adım 3, 2 resimden 2.
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: adım 4, 2 resimden 1. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: adım 4, 2 resimden 2.
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: adım 5, 2 resimden 1. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: adım 5, 2 resimden 2.
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Hard Drive Replacement, Drive Removal: adım 6, 1 resimden 1.
    • Pull the drive gently out of the SATA connector.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
9021007
4.599 İtibar
25 adet Kılavuz yazıldı
4 Yorum
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy Gibbons - Yanıt
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Dion Diogo Mar -
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
James Causey - Yanıt
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 114
Her zaman: 4,502
