Ana içeriğe geç
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
Neye ihtiyacın var
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: adım 1, 1 resimden 1.
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 2, 1 resimden 1.
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 3, 2 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 3, 2 resimden 2.
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 4, 2 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 4, 2 resimden 2.
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 5, 2 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 5, 2 resimden 2.
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 6, 1 resimden 1.
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 7, 3 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 7, 3 resimden 2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 7, 3 resimden 3.
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 8, 1 resimden 1.
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 9, 2 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 9, 2 resimden 2.
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 10, 2 resimden 1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 10, 2 resimden 2.
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: adım 11, 1 resimden 1.
    • Gently pull the hose to ensure it is secure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 774
