Ana içeriğe geç
Lamp Pull Chain Replacement
Neye ihtiyacın var
  1. Lamp Pull Chain Replacement, Lamp Pull Chain: adım 1, 1 resimden 1.
    • Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
  2. Lamp Pull Chain Replacement: adım 2, 2 resimden 1. Lamp Pull Chain Replacement: adım 2, 2 resimden 2.
    • Remove the light bulb from the lamp.
  3. Lamp Pull Chain Replacement: adım 3, 2 resimden 1. Lamp Pull Chain Replacement: adım 3, 2 resimden 2.
    • Unscrew the lamp shade from the base by turning it counter-clockwise.
  4. Lamp Pull Chain Replacement: adım 4, 1 resimden 1.
    • Gently pull the socket from the base to expose the broken chain section.
  5. Lamp Pull Chain Replacement: adım 5, 2 resimden 1. Lamp Pull Chain Replacement: adım 5, 2 resimden 2.
    • Attach the chain connector to the extra chain.
  6. Lamp Pull Chain Replacement: adım 6, 2 resimden 1. Lamp Pull Chain Replacement: adım 6, 2 resimden 2.
    • Connect the chain with the chain connector to the broken chain on the lamp base.
  7. Lamp Pull Chain Replacement: adım 7, 3 resimden 1. Lamp Pull Chain Replacement: adım 7, 3 resimden 2. Lamp Pull Chain Replacement: adım 7, 3 resimden 3.
    • Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp.
    • The chain will go down through this hole.
  8. Lamp Pull Chain Replacement: adım 8, 1 resimden 1.
    • Gently push the socket back into place.
  9. Lamp Pull Chain Replacement: adım 9, 2 resimden 1. Lamp Pull Chain Replacement: adım 9, 2 resimden 2.
    • Screw the lamp shade back onto the base of the lamp by turning it clockwise.
  10. Lamp Pull Chain Replacement: adım 10, 1 resimden 1.
    • Replace the light bulb into the lamp socket.
  11. Lamp Pull Chain Replacement: adım 11, 2 resimden 1. Lamp Pull Chain Replacement: adım 11, 2 resimden 2.
    • Plug your lamp into an outlet and turn it on!
    • You will pull down on the chain to do this.
  12. Lamp Pull Chain Replacement: adım 12, 1 resimden 1.
    • Congratulations! You have fixed your lamp.
Sonuç
Congratulations on fixing your lamp!
5 farklı kişi bu kılavuzu tamamladı.
Anna Rill
358 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
You saved my lamp! Thank you for this simple to follow guide.
Erica Chiovarou - Yanıt
All well and good, but isn’t it more likely that the break will be in the string which runs from the chain into the switch? This can be fixed by disassembling the switch itself - but where can one buy the right string?
gregg.horne - Yanıt
On my lamp, the problem was not the chain but in the switch itself. This made it necessary to replace the entire socket since the switch was riveted to its base. I made this video which shows how to replace the socket and switch:https://youtu.be/0fLnUPWzLeI
Scott Clark - Yanıt
Excellent, Thank you!
mtrujillo88@hotmail.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 173
Son 30 gün: 738
Her zaman: 34,959
