Ana içeriğe geç
Large Animal Water Nipple Replacement
Neye ihtiyacın var
  1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: adım 1, 1 resimden 1.
    • Empty the container of all water.
  2. Large Animal Water Nipple Replacement: adım 2, 1 resimden 1.
    • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
  3. Large Animal Water Nipple Replacement: adım 3, 1 resimden 1.
    • Pull the mechanism out from the front.
  4. Large Animal Water Nipple Replacement: adım 4, 1 resimden 1.
    • Ensure there is no damage to the hole that needs to be patched.
    • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
  5. Large Animal Water Nipple Replacement: adım 5, 1 resimden 1.
    • Use Teflon tape to line the threads of the new nipple.
  6. Large Animal Water Nipple Replacement: adım 6, 2 resimden 1. Large Animal Water Nipple Replacement: adım 6, 2 resimden 2.
    • Place the new nipple in the hole with the peg on top.
  7. Large Animal Water Nipple Replacement: adım 7, 1 resimden 1.
    • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
    • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
    • This is a leak in the seal.
  8. Large Animal Water Nipple Replacement: adım 8, 1 resimden 1.
    • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
    • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
  9. Large Animal Water Nipple Replacement: adım 9, 1 resimden 1.
    • Place and thread the nut on the inside of the container on the backside of the nipple.
  10. Large Animal Water Nipple Replacement: adım 10, 1 resimden 1.
    • Finally, place the container in the designated place and fill completely.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 187
