Ana içeriğe geç
Laser Lens Cleaning
Neye ihtiyacın var
  1. Laser Lens Cleaning, Top Panel: adım 1, 2 resimden 1. Laser Lens Cleaning, Top Panel: adım 1, 2 resimden 2.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    FixBot'a Sor
    Yorum Ekle
  2. Laser Lens Cleaning: adım 2, 2 resimden 1. Laser Lens Cleaning: adım 2, 2 resimden 2.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Laser Lens Cleaning, Laser Lens Cleaning: adım 3, 2 resimden 1. Laser Lens Cleaning, Laser Lens Cleaning: adım 3, 2 resimden 2.
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Nathan Klammer
521 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G20
4 Üyeler
9 adet Kılavuz yazıldı
5Kılavuz Yorumları
This item was not appropriate, thank you for trying.
bigd734 - Yanıt Paylaş
Works on Samsung's box(home theater), thank you!
CarlBraun - Yanıt Paylaş
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Yanıt Paylaş
ne fonctionne toujours pas
JEAN PIERRE LARVOR - Yanıt Paylaş
My problem I think is alignment
James Smith - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 39
Son 7 gün: 143
Son 30 gün: 632
Her zaman: 61,431
