Ana içeriğe geç
Lasko Box Fan Back Wire Repair
Neye ihtiyacın var
    1. Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: adım 1, 3 resimden 1. Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: adım 1, 3 resimden 2. Lasko Box Fan Back Wire Repair, Lasko Box Fan Back Wire Repair: adım 1, 3 resimden 3.
      • Make sure the fan is unplugged.
      • Unscrew the 6 screws on the front of the fan.
      • Remove the face plate.
      • Flip the fan and repeat for the 6 screws on the back. They are in the same position as the front.
      FixBot'a Sor
      Yorum Ekle
    2. Lasko Box Fan Back Wire Repair: adım 2, 2 resimden 1. Lasko Box Fan Back Wire Repair: adım 2, 2 resimden 2.
      • Unscrew the screws attaching the motor/blades to the frame.
      • Unscrew the screws attaching the plastic frame to the motor.
      • The blades cannot be removed from the motor.
      FixBot'a Sor
      Yorum Ekle
    3. Lasko Box Fan Back Wire Repair: adım 3, 2 resimden 1. Lasko Box Fan Back Wire Repair: adım 3, 2 resimden 2.
      • Strip the wires using wire strippers.
      FixBot'a Sor
      Yorum Ekle
    4. Lasko Box Fan Back Wire Repair: adım 4, 1 resimden 1.
      • Twist the ends of the wire together
      • Place wires in soldering kit arms.
      FixBot'a Sor
      Yorum Ekle
    5. Lasko Box Fan Back Wire Repair: adım 5, 2 resimden 1. Lasko Box Fan Back Wire Repair: adım 5, 2 resimden 2.
      • Plug in the soldering iron.
      • When the soldering iron is hot, solder the wires together.
      • Place the tip of the soldering iron on the wires directly.
      • Place the solder on the wire.
      • Remove the solder and soldering iron from the wire
      • Repeat this step with the second wire.
      • Soldering irons are very hot!
      FixBot'a Sor
      Yorum Ekle
    6. Lasko Box Fan Back Wire Repair: adım 6, 3 resimden 1. Lasko Box Fan Back Wire Repair: adım 6, 3 resimden 2. Lasko Box Fan Back Wire Repair: adım 6, 3 resimden 3.
      • Use electrical tape to insulate the wires.
      • Wrap the tape around each wire.
      • Wrap tape around the outside of all of the wires.
      • Make sure to completely cover any exposed wire.
      FixBot'a Sor
      Yorum Ekle
    7. Lasko Box Fan Back Wire Repair: adım 7, 2 resimden 1. Lasko Box Fan Back Wire Repair: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Clean out the dust from the blades and motor using tweezers.
      FixBot'a Sor
      Yorum Ekle
    8. Lasko Box Fan Back Wire Repair: adım 8, 3 resimden 1. Lasko Box Fan Back Wire Repair: adım 8, 3 resimden 2. Lasko Box Fan Back Wire Repair: adım 8, 3 resimden 3.
      • Tape wires along the frame to prevent further damage.
      • Put the face plates back on and enjoy!
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zach Emard
227 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-1, Green Fall 2015 Cal Poly, Team 14-1, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G1
4 Üyeler
4 adet Kılavuz yazıldı
8Kılavuz Yorumları
Any tips for replacing the "Blue Plug" fuse after it's mysteriously blown in a Lasko box fan?
https://www.amazon.com/fused-safety-Lask...
I could hillbilly wire up a new plug to minimize the wire work, but don't want to start a fire either.
Zac Appleton - Yanıt Paylaş
I would also like to know how to replace the plug end after the non-replaceable fuse inside the plug is blown.
Gung Ho - Yanıt Paylaş
I don't know bout you but I was able to “pop" my fan blades right off of motor. Now I'm just going to replace plug end and see if it'll work since fixing wires didn't help.
(Yep found fuse was blown. Why would they make the fuse non replaceable when they eventually blow? Wonder how many fans people have thrown out all because of a blown fuse??
Steff Lusher - Yanıt Paylaş
That's exactly why it is non replaceable..
Throw it away and buy a NEW one.
2nd Son Home Services - Yanıt Paylaş
Not one thing worked
zakkerycastine876 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 110
Her zaman: 24,442
