Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Type the following command, this will create a backup folder on your desktop for your launchpad app.
mkdir ~/Desktop/DB_Backup
Type the following command to copy the database. This will place it in the back folder that was created in the second step.
cp ~/Library/Application\ Support/Dock/*.db ~/Desktop/DB_Backup/
Type the next command, this will put the LaunchPad back to its original setup and will take all programs out of folders.
sqlite3 ~/Library/Application\ Support/Dock/*.db 'DELETE from apps;' \ ' DELETE from groups WHERE title<>""; DELETE from items WHERE rowid>2;' \ && killall Dock
However, it should be noted that the folders will not disappear. To get rid of them, simply load at least one app into Launchpad, then drag the app into & out of the folder. It will 'evaporate' when it's empty.
If you want to do a full reset of the LaunchPad, I will create another guide for those steps.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
this command gives a syntax error in High Sierra.
It is a very simple method.<a href="https://technumus.com/how-to-remove-icon...>HOW TO REMOVE ICONS FROM DESKTOP MAC</a>
