Neye ihtiyacın var
Socket wrench, and 5/16 inch and 9/32 inch sockets
Pliers
Container for gasoline
Take off the air filter cover.
Remove the filter element to access the carburetor mounting screws.
Remove the 2 screws marked "A" on the photo with a 5/16 inch socket.
Remove the 2 screws marked "B" on the photo with the 9/32 inch socket wrench.
Detach the housing by disconnecting the breather hose.
Remove the housing.
Slide the tank up to unhook it.
Pull the carburetor towards you.
Tilt it downwards to separate the rod from the regulator marked "C" in the photo.
Reconnect the hose from the tank to the carburetor.
Reposition the spring clamp with the pliers.
Holding the carburetor on its side, insert the throttle rod onto the throttle plate control.
Rotate the assembly up 90° and position the carburetor on the intake pipe.
Slide the fuel tank into its mounting notches.
Refit the breather hose.
Reposition the air filter housing, taking care to align the screw holes with the support bracket.
Tighten the 2 screws marked "A" on the photo with a 5/16 inch socket.
Tighten the 2 screws marked "B" on the photo with a 9/32 inch socket.
Refit the filter element and the cover, taking care to align the notches in the cover.
Reposition the pull starter and secure it with the three screws using the 5/16 inch socket.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
