Ana içeriğe geç
Le Pan II Charging Port Replacement
Neye ihtiyacın var
  1. Le Pan II Charging Port Replacement, Screen: adım 1, 2 resimden 1. Le Pan II Charging Port Replacement, Screen: adım 1, 2 resimden 2.
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Charging Port Replacement: adım 2, 2 resimden 1. Le Pan II Charging Port Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Charging Port Replacement: adım 3, 2 resimden 1. Le Pan II Charging Port Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove grey metal backing from screen.
  5. Le Pan II Charging Port Replacement: adım 5, 1 resimden 1.
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Charging Port Replacement: adım 6, 1 resimden 1.
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Charging Port Replacement, Charging Port: adım 7, 1 resimden 1.
    • Use the Phillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should be 8 (3.5 mm) screws to the motherboard.
  8. Le Pan II Charging Port Replacement: adım 8, 1 resimden 1.
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1mm) screws to the fan.
  9. Le Pan II Charging Port Replacement: adım 9, 1 resimden 1.
    • Use the metal spudger to pry off the charging port from the motherboard.
Sonuç
Kelly Moniz
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G3
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I have had no luck getting in touch with anyone in the customer service department.I have left several messages but have not heard from anyone yet. I just need to know how I can get a charge port for my daughters tablet. She had it 6 months before the charge port went out.
tashiarmarshall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 1,216
