Ana içeriğe geç
Le Pan II Motherboard Replacement
Neye ihtiyacın var
  1. Le Pan II Motherboard Replacement, Screen: adım 1, 2 resimden 1. Le Pan II Motherboard Replacement, Screen: adım 1, 2 resimden 2.
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Motherboard Replacement: adım 2, 2 resimden 1. Le Pan II Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Motherboard Replacement: adım 3, 2 resimden 1. Le Pan II Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove grey metal backing from screen.
  5. Le Pan II Motherboard Replacement: adım 5, 1 resimden 1.
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Motherboard Replacement, Battery: adım 7, 1 resimden 1.
    • Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
  8. Le Pan II Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Use the Plillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should 8 (3.5mm) screws
  9. Le Pan II Motherboard Replacement: adım 9, 1 resimden 1.
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1 mm) screws for the fan.
    • Note: From here, you can simply lift and remove the motherboard from the rest of the device.
Sonuç
Kelly Moniz
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 174
