Ana içeriğe geç
Le Pan S Battery Replacement
Neye ihtiyacın var
    1. Le Pan S Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      FixBot'a Sor
      Yorum Ekle
    2. Le Pan S Battery Replacement: adım 2, 2 resimden 1. Le Pan S Battery Replacement: adım 2, 2 resimden 2.
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      FixBot'a Sor
      Yorum Ekle
    3. Le Pan S Battery Replacement: adım 3, 1 resimden 1.
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      FixBot'a Sor
      Yorum Ekle
    4. Le Pan S Battery Replacement: adım 4, 2 resimden 1. Le Pan S Battery Replacement: adım 4, 2 resimden 2.
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maria Dole
395 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S2G1
5 Üyeler
10 adet Kılavuz yazıldı
5Kılavuz Yorumları
where can I purchase a battery for a tc978
Timothy - Yanıt Paylaş
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel - Yanıt Paylaş
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Yanıt Paylaş
Where can I purchase the battery needed?????????????????
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 5,903
