Ana içeriğe geç
Le Pan S Camera Replacement
Neye ihtiyacın var
    1. Le Pan S Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      FixBot'a Sor
      Yorum Ekle
    2. Le Pan S Camera Replacement: adım 2, 2 resimden 1. Le Pan S Camera Replacement: adım 2, 2 resimden 2.
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      FixBot'a Sor
      Yorum Ekle
    3. Le Pan S Camera Replacement: adım 3, 1 resimden 1.
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      FixBot'a Sor
      Yorum Ekle
    4. Le Pan S Camera Replacement: adım 4, 2 resimden 1. Le Pan S Camera Replacement: adım 4, 2 resimden 2.
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      FixBot'a Sor
      Yorum Ekle
    1. Le Pan S Camera Replacement, Camera: adım 5, 1 resimden 1.
      • Remove the four 3.5 mm Phillips #00 screws from the circuit board near the bottom of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Le Pan S Camera Replacement: adım 6, 1 resimden 1.
      • Lift and pull the volume rocker up so it is out of the way of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Le Pan S Camera Replacement: adım 7, 2 resimden 1. Le Pan S Camera Replacement: adım 7, 2 resimden 2.
      • Remove the zero insertion force connector (ZIF) by using a plastic opening tool, spudger, or fingernail to lift retaining flap.
      FixBot'a Sor
      Yorum Ekle
    4. Le Pan S Camera Replacement: adım 8, 2 resimden 1. Le Pan S Camera Replacement: adım 8, 2 resimden 2.
      • Slightly lift up the green electrical board and pull out the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tyler Ziliak
110 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S2G1
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 490
