Ana içeriğe geç
Le Pan S Volume Rocker Replacement
Neye ihtiyacın var
  1. Le Pan S Volume Rocker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Volume Rocker Replacement: adım 2, 2 resimden 1. Le Pan S Volume Rocker Replacement: adım 2, 2 resimden 2.
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Volume Rocker Replacement: adım 3, 1 resimden 1.
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Volume Rocker Replacement: adım 4, 2 resimden 1. Le Pan S Volume Rocker Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Volume Rocker Replacement, Volume Rocker: adım 5, 1 resimden 1.
    • Remove the four 2.5 mm Phillips #00 head screws from the circuit board near the top of the tablet.
  6. Le Pan S Volume Rocker Replacement: adım 6, 1 resimden 1.
    • Pull out the volume rocker by carefully moving it side to side with your fingers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wiaam Elkhatib
199 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S2G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 218
