Ana içeriğe geç
Leader Impression i10A-LE Back Facing Camera Replacement
Neye ihtiyacın var
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: adım 1, 2 resimden 1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: adım 1, 2 resimden 2.
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: adım 2, 3 resimden 1. Leader Impression i10A-LE Back Facing Camera Replacement: adım 2, 3 resimden 2. Leader Impression i10A-LE Back Facing Camera Replacement: adım 2, 3 resimden 3.
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: adım 3, 3 resimden 1. Leader Impression i10A-LE Back Facing Camera Replacement: adım 3, 3 resimden 2. Leader Impression i10A-LE Back Facing Camera Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: adım 4, 3 resimden 1. Leader Impression i10A-LE Back Facing Camera Replacement: adım 4, 3 resimden 2. Leader Impression i10A-LE Back Facing Camera Replacement: adım 4, 3 resimden 3.
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 199
