Ana içeriğe geç
Leader Impression i10A-LE Battery Pack Replacement
Neye ihtiyacın var
  1. Leader Impression i10A-LE Battery Pack Replacement, Battery Pack: adım 1, 1 resimden 1.
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Battery Pack Replacement: adım 2, 3 resimden 1. Leader Impression i10A-LE Battery Pack Replacement: adım 2, 3 resimden 2. Leader Impression i10A-LE Battery Pack Replacement: adım 2, 3 resimden 3.
    • Use the plastic prying tools to crack open the back of the device.
    • Once cracked, use more plastic prying tools to fully remove the back panel. A popping noise will occur when each clip is opened.
    • Remove the back panel and set aside.
  3. Leader Impression i10A-LE Battery Pack Replacement: adım 3, 2 resimden 1. Leader Impression i10A-LE Battery Pack Replacement: adım 3, 2 resimden 2.
    • The battery pack is glued to the device.
    • Use a spudger to pry the battery pack from the glue.
    • Desolder the positive (red) and negative (black) power leads.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 571
