Ana içeriğe geç
Leader Impression i10A-LE Front Facing Camera Replacement
Neye ihtiyacın var
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: adım 1, 2 resimden 1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: adım 1, 2 resimden 2.
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: adım 3, 1 resimden 1.
    • Remove the camera from it's slot.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 118
