Ana içeriğe geç
Leader Impression i10A-LE Microphone Replacement
Neye ihtiyacın var
  1. Leader Impression i10A-LE Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Orient your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Microphone Replacement: adım 2, 3 resimden 1. Leader Impression i10A-LE Microphone Replacement: adım 2, 3 resimden 2. Leader Impression i10A-LE Microphone Replacement: adım 2, 3 resimden 3.
    • Pry the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Microphone Replacement: adım 3, 2 resimden 1. Leader Impression i10A-LE Microphone Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the positive and negative battery leads.
    • Remove the microphone from plastic housing with the tweezers.
    • Desolder the positive (red) and negative (black) power leads.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 113
