Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
If the laser is not turning on, or flickering, the problem may be caused by a faulty leaf spring. In order to replace this part, follow the steps in this guide.
  1. Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside. Lift the side of the blaster off exposing its internal parts. Lift the side of the blaster off exposing its internal parts.
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Work the trigger to ensure the problem is the switch not making a proper connection.
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  5. Use a hot soldering iron to melt the solder of the two wires at the rear of the switch.  Take note that the red wire leads from the top of the switch.
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffrey Sargeant
318 İtibar
1 Kılavuz yazıldı
Takım
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G8
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,484
