Ana içeriğe geç
N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
Neye ihtiyacın var
  1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: adım 1, 1 resimden 1.
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: adım 2, 3 resimden 1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: adım 2, 3 resimden 2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: adım 2, 3 resimden 3.
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: adım 3, 1 resimden 1.
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: adım 4, 1 resimden 1.
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffrey Sargeant
354 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G8
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,947
