Ana içeriğe geç
LeapFrog LeapPad Platinum Battery Replacement
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Battery Replacement: adım 2, 2 resimden 1. LeapFrog LeapPad Platinum Battery Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: adım 3, 2 resimden 1. LeapFrog LeapPad Platinum Battery Replacement: adım 3, 2 resimden 2.
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: adım 4, 1 resimden 1.
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: adım 5, 3 resimden 1. LeapFrog LeapPad Platinum Battery Replacement: adım 5, 3 resimden 2. LeapFrog LeapPad Platinum Battery Replacement: adım 5, 3 resimden 3.
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Battery Replacement: adım 6, 1 resimden 1.
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brittney Cooper
191 İtibar
1 Kılavuz yazıldı
UW Tacoma, Team 1-5, Rose Winter 2016 UW Tacoma, Team 1-5, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G5
4 Üyeler
8 adet Kılavuz yazıldı
One Comment
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 7,501
