Ana içeriğe geç
LeapFrog LeapPad Ultimate Back Panel Replacement
Neye ihtiyacın var
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: adım 2, 2 resimden 1. LeapFrog LeapPad Ultimate Back Panel Replacement: adım 2, 2 resimden 2.
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 1,188
