Ana içeriğe geç
LeapFrog LeapPad Ultimate Camera Replacement
Neye ihtiyacın var
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: adım 1, 2 resimden 1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: adım 2, 2 resimden 1. LeapFrog LeapPad Ultimate Camera Replacement: adım 2, 2 resimden 2.
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: adım 4, 3 resimden 1. LeapFrog LeapPad Ultimate Camera Replacement: adım 4, 3 resimden 2. LeapFrog LeapPad Ultimate Camera Replacement: adım 4, 3 resimden 3.
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: adım 5, 1 resimden 1.
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: adım 6, 2 resimden 1. LeapFrog LeapPad Ultimate Camera Replacement: adım 6, 2 resimden 2.
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: adım 7, 1 resimden 1.
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 215
