Giriş
The screen of any device is one of the most delicate parts. This guide will walk you through how to replace your LCD screen.
Neye ihtiyacın var
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Bu adımda kullanılan alet:Tweezers$4.99
The segment connecting the battery to the motherboard will consist of red, white, and black wires.
There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Where did you find a Replacement screen? Are there any identifying part numbers?
