Ana içeriğe geç
LeapFrog LeapPad Ultra XDi Screen Replacement
Neye ihtiyacın var
  1. LeapFrog LeapPad Ultra XDi Screen Replacement, Battery: adım 1, 2 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 2, 2 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 3, 3 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 3, 3 resimden 2. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 3, 3 resimden 3.
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 4, 2 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 4, 2 resimden 2.
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 5, 2 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 5, 2 resimden 2.
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 6, 3 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 6, 3 resimden 2. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 6, 3 resimden 3.
    • Use the Spudger to remove the glued down battery.
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Replace the battery with a new one.
  7. LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: adım 7, 3 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: adım 7, 3 resimden 2. LeapFrog LeapPad Ultra XDi Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
  9. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 9, 3 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 9, 3 resimden 2. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 9, 3 resimden 3.
    • Pull the two side grips up to remove them from the casing.
    • Unscrew the eight 7.0 mm Phillips #1 screws securing the base. Remove the base.
  10. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 10, 2 resimden 1. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 10, 2 resimden 2.
    • Unscrew the eleven 7.0 mm Phillips #1 screws securing the circuit board to the case. Remove the circuit board.
  11. LeapFrog LeapPad Ultra XDi Screen Replacement: adım 11, 1 resimden 1.
    • Lift the screen from the front case. Replace the screen.
Sonuç
2 Yorum
Where exactly can I find a replacement screen? I have looked everywhere with no luck.
Siblings have a cracked one i would really like to fix so any help would be greatly appreciated.
Derp Dude - Yanıt
So I would suggest ebay or buy one that's not chargable on macari and use it for parts that's the route I'm taking with what ever I find .hope that helps since this post is old
Cherry -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 851
