Ana içeriğe geç
LeapFrog LeapPad2 Explorer Back Camera Replacement
Neye ihtiyacın var
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: adım 1, 2 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 2, 3 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 2, 3 resimden 2. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 2, 3 resimden 3.
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: adım 3, 2 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: adım 3, 2 resimden 2.
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 4, 3 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 4, 3 resimden 2. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: adım 5, 2 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: adım 5, 2 resimden 2.
    • Locate the back camera below the game cartridge.
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 6, 2 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 6, 2 resimden 2.
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 7, 2 resimden 1. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 7, 2 resimden 2.
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: adım 8, 1 resimden 1.
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
Sonuç
Nupur Garg
867 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G10
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,179
