Ana içeriğe geç
LeapFrog LeapTV Controller Button Replacement
Neye ihtiyacın var
  1. LeapFrog LeapTV Controller Button Replacement, Battery: adım 1, 1 resimden 1.
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: adım 2, 1 resimden 1.
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: adım 3, 1 resimden 1.
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: adım 4, 1 resimden 1.
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: adım 5, 1 resimden 1.
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: adım 6, 1 resimden 1.
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: adım 7, 1 resimden 1.
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: adım 8, 1 resimden 1.
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: adım 9, 1 resimden 1.
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: adım 10, 1 resimden 1.
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: adım 11, 1 resimden 1.
    • Buttons are now removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Triston Fischer
128 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G2, Baechle Spring 2017 IUPUI, Team S4-G2, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 368
