Ana içeriğe geç
LeapFrog LeapTV Controller Joy Stick Replacement
Neye ihtiyacın var
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: adım 1, 1 resimden 1.
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Joy Stick Replacement: adım 2, 1 resimden 1.
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Joy Stick Replacement: adım 3, 1 resimden 1.
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: adım 4, 1 resimden 1.
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Joy Stick Replacement: adım 5, 1 resimden 1.
    • Separate the top and bottom parts of the controller slightly.
  6. LeapFrog LeapTV Controller Joy Stick Replacement: adım 6, 1 resimden 1.
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
  7. LeapFrog LeapTV Controller Joy Stick Replacement: adım 7, 1 resimden 1.
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Joy Stick Replacement: adım 8, 1 resimden 1.
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
  9. LeapFrog LeapTV Controller Joy Stick Replacement: adım 9, 1 resimden 1.
    • Hold the circuit board and button and pull the button off.
  10. LeapFrog LeapTV Controller Joy Stick Replacement: adım 10, 1 resimden 1.
    • Joystick will now pop off.
Sonuç
Joshua Jones
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G2, Baechle Spring 2017 IUPUI, Team S4-G2, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 785
