Ana içeriğe geç
LeapFrog Scribble and Write Display Screen Replacement
Neye ihtiyacın var
    1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: adım 1, 2 resimden 1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: adım 1, 2 resimden 2.
      • Turn your toy over.
      • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
      • Be careful to keep track of the screws.
      FixBot'a Sor
      Yorum Ekle
    2. LeapFrog Scribble and Write Display Screen Replacement: adım 2, 1 resimden 1.
      • Carefully remove the back of the toy..
      FixBot'a Sor
      Yorum Ekle
    3. LeapFrog Scribble and Write Display Screen Replacement: adım 3, 2 resimden 1. LeapFrog Scribble and Write Display Screen Replacement: adım 3, 2 resimden 2.
      • Use a Philips screwdriver to remove the two screws attached to the motherboard.
      • Remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. LeapFrog Scribble and Write Display Screen Replacement: adım 4, 2 resimden 1. LeapFrog Scribble and Write Display Screen Replacement: adım 4, 2 resimden 2.
      • Remove the screen.
      • Remove the two pins from the bottom of the screen.
      FixBot'a Sor
      Yorum Ekle
    5. LeapFrog Scribble and Write Display Screen Replacement: adım 5, 1 resimden 1.
      • Use a Phillips screwdriver to remove the screw from the green clip that holds the two screen layers together.
      FixBot'a Sor
      Yorum Ekle
    6. LeapFrog Scribble and Write Display Screen Replacement: adım 6, 2 resimden 1. LeapFrog Scribble and Write Display Screen Replacement: adım 6, 2 resimden 2.
      • Separate the blue and the white films.
      • Clean both films with paper towel.
      • Make sure there are no dirty spots before putting the films back together.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shang
328 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 52
Her zaman: 5,126
