Ana içeriğe geç
LeapFrog Scribble and Write Eraser Slider Cleaning
Neye ihtiyacın var
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: adım 1, 1 resimden 1.
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 3, 1 resimden 1.
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 4, 2 resimden 1. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 5, 1 resimden 1.
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 6, 2 resimden 1. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 6, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: adım 7, 1 resimden 1.
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Sonuç
Shang
328 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 948
