Ana içeriğe geç
LeapFrog Scribble and Write Motherboard Replacement
Neye ihtiyacın var
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the volume control switch from the motherboard with the soldering iron.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shang
328 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 641
