Ana içeriğe geç
LeapPad Ultra Battery Replacement
Neye ihtiyacın var
  1. LeapPad Ultra Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: adım 4, 1 resimden 1.
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: adım 5, 1 resimden 1.
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: adım 6, 2 resimden 1. LeapPad Ultra Battery Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
Sonuç
To reassemble the device, follow these instructions in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
Ryan Arredondo
246 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G99
4 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - Yanıt
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - Yanıt
What is a spudger and where do I get a battery
P Mac - Yanıt
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 16,103
