Ana içeriğe geç
Leapfrog LeapPad 3 Battery Replacement
Neye ihtiyacın var
    1. Leapfrog LeapPad 3 Battery Replacement, Battery: adım 1, 3 resimden 1. Leapfrog LeapPad 3 Battery Replacement, Battery: adım 1, 3 resimden 2. Leapfrog LeapPad 3 Battery Replacement, Battery: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
      • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
      • You will not need to pry the case off.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog LeapPad 3 Battery Replacement: adım 2, 3 resimden 1. Leapfrog LeapPad 3 Battery Replacement: adım 2, 3 resimden 2. Leapfrog LeapPad 3 Battery Replacement: adım 2, 3 resimden 3.
      • Unplug the battery from the motherboard with your hands.
      • The battery sits to the right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog LeapPad 3 Battery Replacement: adım 3, 2 resimden 1. Leapfrog LeapPad 3 Battery Replacement: adım 3, 2 resimden 2.
      • Pry the battery gently off of the plastic platform with an opening tool.
      • Do not to puncture the battery, as the material inside can be dangerous.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Matt Irvine
952 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G2
3 Üyeler
42 adet Kılavuz yazıldı
1Rehber Yorum
where can i purchase a battery, i have googled and come up with nothing.
martinez2503 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 54
Her zaman: 5,057
