Ana içeriğe geç
Leapfrog LeapPad 3 Front Facing Camera Replacement
Neye ihtiyacın var
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: adım 1, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: adım 1, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
      • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
      • You will not need to pry the case off.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 2, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 2, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 2, 3 resimden 3.
      • Unplug the battery from the motherboard with your hands.
      • The battery sits to the right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 3, 2 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 3, 2 resimden 2.
      • Pry the battery gently off of the plastic platform with an opening tool.
      • Do not to puncture the battery, as the material inside can be dangerous.
      FixBot'a Sor
      Yorum Ekle
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: adım 4, 2 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: adım 4, 2 resimden 2.
      • Disconnect the audio cord from the motherboard using a plastic opening tool.
      • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
      • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 5, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 5, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 5, 3 resimden 3.
      • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 6, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 6, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 6, 3 resimden 3.
      • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
      • Remove the board and speaker from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: adım 7, 2 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: adım 7, 2 resimden 2.
      • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 8, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 8, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 8, 3 resimden 3.
      • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 9, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 9, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 9, 3 resimden 3.
      • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
      • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
      • The device was rotated 180 degrees in order to unplug the display assembly cord.
      FixBot'a Sor
      Yorum Ekle
    1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: adım 10, 2 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: adım 10, 2 resimden 2.
      • Unscrew the eight 6.5 mm phillips screws from the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 11, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 11, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 11, 3 resimden 3.
      • Remove the covering with your hand to expose the front facing camera.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 12, 3 resimden 1. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 12, 3 resimden 2. Leapfrog LeapPad 3 Front Facing Camera Replacement: adım 12, 3 resimden 3.
      • Remove the front facing camera from the outer case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matt Irvine
952 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 575
