Ana içeriğe geç
Leapfrog LeapPad 3 Motherboard Replacement
Neye ihtiyacın var
  1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Leapfrog LeapPad 3 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Motherboard Replacement: adım 2, 3 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement: adım 2, 3 resimden 2. Leapfrog LeapPad 3 Motherboard Replacement: adım 2, 3 resimden 3.
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Motherboard Replacement: adım 3, 2 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement: adım 3, 2 resimden 2.
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  5. Leapfrog LeapPad 3 Motherboard Replacement: adım 5, 3 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement: adım 5, 3 resimden 2. Leapfrog LeapPad 3 Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  6. Leapfrog LeapPad 3 Motherboard Replacement: adım 6, 3 resimden 1. Leapfrog LeapPad 3 Motherboard Replacement: adım 6, 3 resimden 2. Leapfrog LeapPad 3 Motherboard Replacement: adım 6, 3 resimden 3.
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Matt Irvine
952 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G2
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,450
