Ana içeriğe geç
Leapfrog My Own Leaptop Battery Replacement Guide
Neye ihtiyacın var
    1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: adım 1, 1 resimden 1.
      • Flip over device so that back portion of the device is facing you.
      FixBot'a Sor
      Yorum Ekle
    2. Leapfrog My Own Leaptop Battery Replacement Guide: adım 2, 1 resimden 1.
      • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
      • Please note that the screw cannot be removed as it is attached to the battery cover.
      FixBot'a Sor
      Yorum Ekle
    3. Leapfrog My Own Leaptop Battery Replacement Guide: adım 3, 2 resimden 1. Leapfrog My Own Leaptop Battery Replacement Guide: adım 3, 2 resimden 2.
      • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
      • Remove the three AA batteries.
      • Note the direction of the batteries for when reassembling.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jonathan Fitzer
629 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G6
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 76
Her zaman: 4,584
