Ana içeriğe geç
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Neye ihtiyacın var
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: adım 1, 1 resimden 1.
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 2, 1 resimden 1.
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 3, 2 resimden 1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 3, 2 resimden 2.
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: adım 4, 1 resimden 1.
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 5, 1 resimden 1.
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 6, 2 resimden 1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 6, 2 resimden 2.
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 7, 1 resimden 1.
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 8, 3 resimden 1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 8, 3 resimden 2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 8, 3 resimden 3.
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 9, 2 resimden 1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 9, 2 resimden 2.
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 10, 3 resimden 1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 10, 3 resimden 2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: adım 10, 3 resimden 3.
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Fitzer
584 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 üyesi
USFT-LACY-S16S14G6
4 Üyeler
6 adet Kılavuz yazıldı
6 Yorum
Very useful. but where to get a new membrane? please help
Alina Timchenko - Yanıt
Didn't work. I'll buy a new toy.
victoria_nglover19 - Yanıt
Is the screen on this suppose to light up?
stewartmelinda41 - Yanıt
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 5,160
