Ana içeriğe geç
Lefant M210 Wheel Assembly Replacement
Neye ihtiyacın var
    1. Lefant M210 Wheel Assembly Replacement, Brush: adım 1, 2 resimden 1. Lefant M210 Wheel Assembly Replacement, Brush: adım 1, 2 resimden 2.
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      FixBot'a Sor
      Yorum Ekle
    2. Lefant M210 Wheel Assembly Replacement: adım 2, 3 resimden 1. Lefant M210 Wheel Assembly Replacement: adım 2, 3 resimden 2. Lefant M210 Wheel Assembly Replacement: adım 2, 3 resimden 3.
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      FixBot'a Sor
      Yorum Ekle
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      FixBot'a Sor
      Yorum Ekle
    1. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: adım 4, 1 resimden 1.
      • Use a Phillips screwdriver to remove four screws near each wheel.
      FixBot'a Sor
      Yorum Ekle
    2. Lefant M210 Wheel Assembly Replacement: adım 5, 2 resimden 1. Lefant M210 Wheel Assembly Replacement: adım 5, 2 resimden 2.
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      FixBot'a Sor
      Yorum Ekle
    3. Lefant M210 Wheel Assembly Replacement: adım 6, 3 resimden 1. Lefant M210 Wheel Assembly Replacement: adım 6, 3 resimden 2. Lefant M210 Wheel Assembly Replacement: adım 6, 3 resimden 3.
      • Hold the wheel up and detach the connector to release it from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Adrian pg
147 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-4, Kershman Fall 2024 CSU Los Angeles, Team 2-4, Kershman Fall 2024 üyesi
CSULA-KERSHMAN-F24S2G4
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 29
Son 30 gün: 161
Her zaman: 2,028
