Ana içeriğe geç
Lego Dimensions Starter Pack USB Cable Replacement
Neye ihtiyacın var
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: adım 1, 2 resimden 1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: adım 1, 2 resimden 2.
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: adım 2, 1 resimden 1.
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: adım 3, 1 resimden 1.
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: adım 4, 1 resimden 1.
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: adım 5, 1 resimden 1.
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: adım 6, 1 resimden 1.
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alyssa Lach
509 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G2, Baechle Fall 2017 IUPUI, Team S5-G2, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S5G2
2 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Where do you buy the USB cable from?
jaimea371 - Yanıt
mguzmanv - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 56
Her zaman: 5,489
